Centre console removal
Paul Fraser
How do you remove the centre console in pre oval dash cars? I've had a potter and am stumped and can't find it in the Haynes manual or the 944 Workshop manuals.
Haynes manuals uugh! Detail everything apart from what you want to know. My sunroof got stuck open last week and they don't even mention a sunroof. Replaced mine on 924 a long while ago and - as same- think have instructions in 924 manual.
from memory - at my age not that good - (someone else will post details - probably Fen). Remove gear knob, pull and twist, and gater, carpet bit. 2 screws on each side of console. Apart from wiring, shoud come off. Note - disconect battery and if changing the dials. There are a lot of connections so I would recommend labaling them before letting rip. Also connections under ashtray which you need to remove and label.
Hope this helps a bit.
Forgot to mention - remove radio, pulls out with connection at back. Also remove heater control knobs and front, and fag lighter.If your taking dial section out - there is a screw in each corner.
Hope that makes some sort of sence.
ORIGINAL: tiptronic
[FONT=verdana,geneva"] [FONT=verdana,geneva"]Not this time - I've never had a square dash car, so I know nothing about them I'm afraid.[FONT=verdana,geneva"]
