sawood12
I've got a new sunroof switch to install.  How do you remove the centre console trim panel.  I can see two screws behind the ashtray, and two in the top corners when you remove the oddments cubby hole.  I'm assuming that there are probably another two behind the stereo as well?  I would like to confirm before I remove the stereo and the stereo cage.
Once the screws are removed does the panel simply lift off?
Cheers.
Cheers.
