Centre Lock Wheels
bobfair
Yesterday Porsche issued a technical bulletin regarding centre lock wheels for cars that may be used on a race track. Effectively the bulletin increases the tightening torque to 600NM and requies application of optimoly grease to the locking mechanism. Porsche recommends a torque wrench that can read up to 800NM and these are typically 4ft long so not exactly compact. When undoing my wheels that have been tighted to 500NM I can physically lift the car at the front so 600NM is going to be interesting to undo!! Those of you considering centre lock wheels may want to take this into account
Bob,
havent seen the tech bull yet, have you any idea what sparked the change. Does it only affect cars that are used on a race track or does it apply to all gt3,s uses. As you know i have the sealey torque wrench and its goes upto 900nmtrs. The only way i can get the front wheels loosened is to have the wife sit in the car and hold her foot on the footbrake or else the front wheels leaves the ground and spins. did you get the tech bulletin by e mail or what, if you did could you forward.
regards hugh
Hugh
The 600NM is only necessary if you use the car on a circuit. I have a PDF which I can send you if you let me know your E Mail address
