spikey1
as started to make a noise water splashing over the engine this is the video of it https://www.youtube.com/watch?v=_KBGR0GjtUc pic of old one took off I used black rubber sealant better then gasket keep old one on as have cut gasket or take oil pump of as altogether fit new gasket coolant cap I pressured all ok I bleed the system now wait see if any air bubbles keep eye on it for a week or so see when pump starting to go see wheel starting to touch middle bolt at the top of the pump some times some fines brake of at the back of the pump as wheel plastic go in to the engine block will melt if u can not see it ones take old pump off or next service mite come out with the oil can not replace bearing that's were Porsche get us as plastic have buy new one.i see there do upgrade water pump now with metal wheel at the back not original Porsche water pump.
