tony stokes
I need to change my batteryin the Boxster.It is a2003 2.7.When disconnecting it the alarm goes off and only stops when reconnected.Porsche suggested leaving the key in the ignition[position 3 but there only seems to be 2 positions].I tried this but the alarm still came on.I then took out relevant fuses but to no avail.I was then advised to simply change the battery over as quickly as possible and just put up wit
h the noise.Anyone out there with any advice? Finally where would I find the radio code? I t is not in the handbook.Will the Porsche main agent supply it over the phone by me supplying the chassis number?
Many thanks
Tony stokes
Many thanks
Tony stokes
