I've just replaced my battery, and the car started OK and ticked over and seemingly revved OK. But on taking it out there was a serious loss of power, and I had to limp home. Tried again this morning, and symptoms the same, but with a couple of misfires as well. So not usable at the moment.
Now my car is a 1999 model, and the handbook just says do not change the battery with the engine running - it does not mention the technique to avoid car alarm going off. I discovered this 5 years ago when I changed the battery last time. Advice on this forum says to put the key in the ignition when changing the battery. So this time I did this, but alarm went off! Reconnected and thought perhaps the ignition needs to be on. Did this and good news: no alarm. Bad news: car doesn't work!!
Could someone confirm that ignition should be on - rather just having the key in? It will be a blow if I've blown the ecu or something by having the wrong technique.
BTW: The car was running fine beforehand, and the battery started struggling just on the previous 2 mornings. The previous batery was 70AH, the new one supplied by the OPC was 80AH.
Spoke to the OPC Service Manager and told him exactly what I had done. He seemed bemused that there was a problem and just suggested that it might need to "reset itself" and try again tomorrow - which is what I have done.
Any experiences in this area will be useful - at the moment looks like I will be getting the RAC to trailer the car to the OPC next week.
