changing battery
75pno
gents
having purchased a new battery it needed fitting ! so quick flit of the manuel find 'battery removal tool' in tool kit ( small spanner ) remove terminal bang alarm goes off ( very loud ) put wire back on press key fob etc vacate garage, ring paragon ! then get told how to do it properly ! place key in ignition turn to position 2 , open window now remove battery in peace , then change battery and reconnect , switch off ignition lock car , unlock car start up and do radio code , easy ! thanks to the lad at paragon for that vital information , it may be in the book had i read it.
75 pno
I'm pretty sure it is in the book [;)]
It's also in the Technical Articles section:
http://www.porscheclubgbforum.com/tm.asp?m=331718
Good to remind others though [:)]
