Changing factory airbox for a cone filter
- Thread starter Guest
Peter Empson
I certainly never wanted to go back to the standard intake.
The S2 is altogether different and I've yet to find the perfect balance between the great torque of the stock box and the top end of the cone, but its been too cold recently to do much messing around [
John Sims
PCGB Admin
ORIGINAL: Peter Empson
It's a long time ago now, but I put a cone on my Lux (which I think is what you've got) and don't remember loosing any torque (this seems to be more likely with exhaust mods on these cars IMO). I did notice a slight improvement in throttle response, and more willingness to rev particularly at higher revs, oh and the noise was rather nice []
I agree completely. Very much matches my experience with putting a cone on a Lux.
db@944s.co.uk
Have I done something wrong or is this ok?
Having driven the car for a short period after fitting, I find that the sound in the mid-range revs is considerably better and the car feels as though it is breathing easier. [
Incidently I bought the cone on ebay for £19 inc P&P from the states.
Indi9xx
In theory, a well oiled cone or element filter will filter as well, if not better than a standard paper filter and will flow more air... initially... However, a well oiled filter will collect dust very quickly and become clogged, meaning you get reduced performance eventually.
To keep an oiled filter in tip top condition, it needs cleaning a re-oiling on a regular basis (more often than a 12k service)
A cone or replacement element which isnt oiled will flow very nicely... But will be a waste of space, as it will only filter large debris rather than the fine stuff which is just as damaging as the bigger particles.
The problem with cone filters is that unless they are positioned in the correct place, ideally out of the engine bay, they will often loose you power at low road speeds (not engine rpm but car mph) due to the engine bay being full of warm air.. cool air is king with performance, the colder the air, the more oxygen you have per cubic inch, which results in more power.
All the best
Jon Mitchell
sawood12
John Sims
PCGB Admin
ORIGINAL: db@944s.co.uk
I recently changed my box for a cone but noticed there is a small pipe which is now not connected to anything.
Having driven the car for a short period after fitting, I find that the sound in the mid-range revs is considerably better and the car feels as though it is breathing easier. []
I bought my kit from the States and it included a connection for the pipe.
The kit did require some re engineering to get it to work properly but otherwise I was very pleased with the end result.
John Sims
PCGB Admin
ORIGINAL: Indi9xx
......To keep an oiled filter in tip top condition, it needs cleaning a re-oiling on a regular basis (more often than a 12k service)......
Jon Mitchell
I agree. Beaky's cone filter seems to get full of crud in an astonishingly short space of time. They seldom clean up as nicely as a new filter and take ages to dry after rinsing out prior to re oiling.
K&N do a demonstration rig where they blow air through a conventional filter element and a K&N replacement. On the other side of the filters are ping pong balls in acrylic tubes. The K&N ping pong ball rises much higher in the tube and thus "proves" more air is being passed.
I have every confidence that this is the case when comparing new filters but how they compare 5k miles later is anybodies guess.
My main reasons for changing were:-
They take up less room so you can see more of the engine and spot any leaks.
They look cool. [
I like the induction noise but this only has any effect on an NA
eastendr
The 'rollers of truth' will tell about the torque and the G-Tech will tell about the cold air !
Rick.
db@944s.co.uk
Another eBay bargain ... [
John Sims
PCGB Admin
A great K&N Site page for establishing which filter to use is http://www.knfilters.com/search/univcone.aspx
I noticed that K&N now also supply foam socks and mesh bags to put over you filter to try to keep it clean for longer. I then remembered that a standard modification with competition Land Rovers is to put stockings or tights over your K&N. I think this will be something that Beaky will be getting - it also has the advantage that should Belinda find some stockings in Beakys glove box I will be able to explain them away as filter covers. [
John Sims
PCGB Admin
ORIGINAL: Diver944
John if you really want to wear stocking then I think you should just come out and tell Belinda, I am sure she will be very understanding []
Well that is obviously another option. I wonder how many have gone that route as a result of such surprise findings?
John Sims
PCGB Admin
I think the difficulty is hitting that sweet spot in road use and you are perhaps better off looking for an inefficient burn of well oxygenated air over chasing an optimum burn of less well charged air.
sawood12
Indi9xx
You dont want the fuel to vapourise, you want it to be atomised.
Vapourised fuel burns faster and leaner than atomised fuel
In the good old days (pah!) cars needed a hook up to the exhaust manifold, so they could draw warm air during cold running.. this was in the days of carbs, and problems of carb icing in cold weather, where humid cold air, due to the effect of evaporation of the fuel, could cool to many degrees less than the tempreture outside, so even on just cool days, this humid air could freeze into ice.
Cold is good... Warm is bad.
All the best
Jon Mitchell
