steveoz32
I can't post all pics up as I have over 60 pictures alone of the steps I took and close ups of stuff when changing out the first front spring, but thought these may come in handy. If anyone in future searches for this and follows what I did I am not responsible blah blah blah for any injury or damage caused, I'm just posting these up for info
Suspension turret access is under here:
Slide pannel out, pop cap off, and I put a big bar on the top nut to break it:
Loosen steering rod slightly:
Jack hub up to take weight and pressure off of droplink and ARB, use spanner and socket to unbolt:
Easy to remove now with hand:
Compress old spring:
Undo bolts on turret (mark them so you know which way they go):
Pop this out:
and this:
Undo brake line bracket:
Get a big allen key and bar on the calliper:
Gently tap calliper free with soft wood:
Unclip and remove sensor connectors:
Undo sensor block and mount:
It will come free now, compress shock downward by pressing on it, and push wishbone down, turn steering all the way to drivers side to fully extend steering arm, pull strut out:
Undo top nut fully with spring still compressed and don't stand infront of it like me lol, I've had a compressor slip / give way before on previous cars and had a top cap in my chest, it wasn't great....
Remove top nut:
Remove cap / mount:
Remove bearing / sleeve assembly:
No need to remove dust cover or washer if you don't want to, clean up strut (I cleaned off and repainted to stop any corrosion here):
New spring on:
I cleaned bearing sleeve and packed with fresh grease:
Pop everthing back on seating rubber etc correctly and tighten up:
Compress new shorter spring slightly, press down under arch and in:
Bit of silicone lube around the bolts and top to keep it all nice:
Lift up and bolt back on in correct position (need to line up with marks and ensure correct angle of turret):
Replace connector and reroute wires to correct place and connect:
Use something softish to pop these back in:
Line calliper up:
Greased bolts and popped back in:
Jack hub again and put drop link back on:
Put brake line bracket back on:
Wheel:
Replace cover:
Drop car down:
The spotting you see is penetrating oil, I pop that on all bolts before I start, I also degreased the brake disc when I got it all back together.Good idea to wash the arch liners out if you have time.
I haven't taken the back pics off of my phone yet, and I haven't got time to sort them out and upload them at the mo, but will try to get around to that soon.
Cheers,
Pop this out:
and this:
Remove top nut:
Remove cap / mount:
New spring on:
Line calliper up:
Wheel:
Replace cover:
Drop car down:
Cheers,
