944cabby
The brake pad wear sensor light started to show up on my dash a couple of weeks ago, and i suspected i had a sticking piston in one of the front calipers again as there seemed to be some "stiffness" in the steering.
Anyways, today i changed the fronts and fitted some new mintax pads.One of the pistons in the drivers side did indeed seem to be stuck, so i freed it up and fitted the pads which slotted straight in - no issues.
With the passenger side caliper - although all the pistons seemed free,it was difficult to insert the pads - not because of tightness against the caliper plates but because the pads were tight against the actual disc, even with the pistons pushed right back into the caliper.
Took it for a careful short spin and although it felt a better drive the steering still felt heavy - is this likely to change after the bedding in period of the pads?Or should the pads sit loose against the disc?
