I've asked this on the 944 forum but I'm not getting much advice back so thought I'd try here because i think the mechanics are the same on 924s.
How do you change the rear wheels bearings? The inner ones. The outer ones are straight forward but do you attack the troublesome inner ones from the same angle, I.E. Take the outer ones out and keep going. Or do you get under the car and take them out from the back? I've got everything stripped ready to go, CV joints are off, drive shaft, stub axle etc.
Looking at it again i think i need to be under the car, remove a snap ring and then pull them towards me, or tap them through from the other side.
Any help would be appreciated. I ordered a full new set of bearings yesterday so want to be ready to just throw them in.
Cheers Amigos.
Cheers Amigos.
