richardjjs1
For those who haven't done it before
Chock Front Wheels
Loosen Road Wheels
Jack up Rear of car and support it on Axle Stands
Remove Rear Wheels
Remove Rear PU 1 Screw behind Wheel at top of PU on each side
2 Screws under each side skirt
1 Screw under side skirt by each silencer
4 Screws in Engine compartment
Drop PU carefully and release electric connector
Remove Silencer Heat Shield (2) 5 screws each side
Remove Silencer 2 Bolts on Main Clamp to
Remove 3 bolts that hold silencer to Silenced Bracket on side of engine
It may be easier to remove 2 long bolts that hold silencer to silencer bracket first
Remove 2 screws that hold the Plug Cover (These may rust but are under 20.00 from Porsche Main Dealer)
Unclip Plug from Coil Pack (3 each side)
Pull coil pack of plug (3 Each side)
Remove plugs (a 3/8 or 1/4 socket set works best)
Replace Plugs
Repeat on other side
If its not been done recently epact some bolts to be seized.
It should all go back in same order
Not a difficult job and no need to go under car
Chock Front Wheels
Loosen Road Wheels
Remove Rear Wheels
Replace Plugs
