I quite fancy the alcantara wheel, which seems to have a thicker rim and a very grippy surface. I've been told that changing it with the standard smooth leather 3-spoke wheel is very easy, you just remove the airbag fuse, pull off the centre pad, undo the central nut, remove the wheel, replace with the new one, replace the central nut and the centre pad, and finally the fuse, and bob's your uncle! The only problem is that you then need to cancel the fault code for the airbag, presumably courtesy of your local Porsche specialist.
My questions are:
1. Is it actually that simple? I put the correct CS wheel back into the 968 CS I had a few years back but that had no airbag to worry about.
2. Which fuse? The printed table is missing from the inside of the fusebox cover.
3. Torque setting for the wheel nut? If this really matters....
4. Will it actually produce a fault code and can I cancel it?
All hints gratefully received!
My questions are:
