Cheap knock indicator
Sounds like a damn good idea to me Tony.
I think you had better get one right away so that you can tell us how it works on the 944 [;)]
Just out of interest, does the ECU reduce boost as well as timing when it senses knock?
And for those who are really serious about knock, have a look here.
Alan
IIRC not when you have a Guru Chip, as Porsche use the cycling valve to reduce boost and the Guru chip doesn't talk to it. Many Guru chippers have removed the cycling valve completely.
