Clewsey
Hi all,
Got this tonight on my GenII 997 S when I put the car away after a long drive. The check engine light is continually on (not flashing). Porsche Assistance is booked for tomorrow morning but any ideas on if the symptoms below could be down to an emissions issue as the error suggests?
I suspected an issue yesterday. I'll try to explain the symptoms. On leaving home yesterday the car felt quite horrible in slower traffic. It seemed to be revving slightly higher at idle (1k or just above) and on moving off, revved much higher before getting going. On coming to a stop, it almost would gain more momentum before settling. The PDK system felt awful, never smooth. On the motorway, it was fine but once in slower traffic presented the same issue.
Same again this morning/evening in slow traffic but on the motorway, it was again smooth and responsive both in manual or automatic mode (all modes).
On reversing into the garage, the car felt rough, almost giving a vibration from the rear until stopping with a rise of revs with no throttle being applied. Then the light appeared for the first time and stayed on continuously. Cranking the engine results in the error being present. The car sounds rough (almost a rattle or vibrating sound from the right hand side of the engine bay).
Could this be an oxygen sensor or Cat issue and would it likely result with these kind of issues? One more thing which I noticed yesterday. More than likely not connected in any way but PCM had defaulted to showing distances in kms etc with different map views. Looks like it's reset itself? Anyone seen this before?
Cheers,
Simon
Cheers,
Simon
