Had my first experience of a major warning light flashing up on my 996TT today, the one I guess no one wants to see "" "˜Check Engine' light although could be worst I guess. Was driving on the M1 back to London this afternoon starting to smile as traffic was easing up and I got a little space on the road, when out of the blue the "˜Check Engine' light came on the dash, at this point there was no major problem noticed in the drive although I was cruising at a steady 70 mph at the time. Then found as I went to accelerate to overtake I wasn't getting the normal power and felt the car was choking when pressing the accelerator. I decided to carry on driving to London as I only had 30 miles to go on the motorway and decided to keep my speed to a safe 60 mph in the slow lane (many people smiling going past me enjoying the view of overtaking a Porsche which is crawling in the slow lane!) in case I need to pull over. Just before I slowed down to this speed I did try pressing the accelerator down to see what the problem was and noticed the turbo pressure go up to 0.1 so knew that was working as well as it could.
Continued to try and evaluate the problem while driving and noticed the car (in any gear) would struggle upto 2k revs juddering with a lack of power overall. Once I went over 2k revs I got more power and the juddering stopped or reduced to hardly being noticeable. When I reached home the idling was only slightly erratic at stand still, hardly 100 rev +/-, the sound was definitely not normal. From past experience of other cars, I remembered I had a problem with an old car which had similar problems due to an air valve getting stuck, so was guessing the problem this time may also be related to the airflow system.
I have spent some time going through Rentech and this forum to see if any other fellow owners have suffered the same problem or something close. Unfortunately I can't find the exact problem, although there are a few instances of pointers towards the MAF. I can't get hold of my independent guy at the moment and hoping to speak to him tomorrow and possibly crawl the 60 odd miles to see him so he can plug in the diagnostics computer to confirm the problem. In the meantime I thought I would check if there were any thoughts on the possible problem.
Note: I didn't know what a MAF was when I started looking into this problem, but found a topic on Rentech which points it out and made it clear to me. Useful simple diagram - http://www.renntech.org/forums/index.php?showtopic=21293&hl=check+engine
