Hi Folks, ever since the sub zero temps over xmas i keep getting above washer water level warning in dash , filled it many times but after 2 weeks of non use, ie standing on drive, it comes back again, could ice have formed in bottle and expanded it so much it burst? [>:]2006 3.2S
"Check washer fluid level" warning..
- Thread starter ianmac
You need to get behind the wheelarch liner on the passenger side (RHD car). So it's a wheel off, wheelarch liner out job. Fairly easy
Steve Brookes
Moderator
And if you just want to confirm that's the problem first, just fill it up and watch it coming straight out by your feet! [
Steve Brookes
Moderator
Sounds like it's just about gripping. mine came completely adrift...as soon as I put water in, it gushed out of the arch liner. After pushing it back I put a cable tie round it to make sure it stayed in place.
Black80XSA
At least the work completed last week is covered by 12 months warranty - good luck.
