Ok now i have your attention [] Anyone who has had their driveshafts or rear wheel bearings replaced could you have a look at the hub nuts and tell me how many you have? You'll need to remove the hub cap off your wheel to do this, if you have caps on your wheels.
Thanks in advance[]
thanks Phil, pleased to say your entirely normal[] I am awaiting some new ones from Porsche and the part numbers have changed. I am wondering what is going to turn up. There should be a lock nut and a nromal hex nut on both axles.
edit to add.
parts arrived. part numbers may have changed but parts are identical to what came off. So all good.[]
