Being the spanner-wielding petrolhead that I am, I'm coming to the end of doing the 12 000 mile service on my 993. Thoroughly enjoyed it so far [8D]
Does anyone have any experience of the best way to check the dual ignition circuit? One option is to simply remove the lower distributor cap & check that there is resistance to moving the rotor arm, but this only confirms that the belt is working & not the coil.
What about disconnecting the low tension supply to the upper coil/distrubutor, then doing same to lower? If engine runs each time, this would confirm operation of each system.
Will I cause damage if I disconnect one of the LOW tension circuits? [8|]
Thanks, Roddy
Thanks, Roddy
