Checking Oil Level..
- Thread starter cbs
jboult
Usual way is to get the engine fully warmed up - 20 minutes or so of driving - so that the temperature gauge reads at about 1/4. Leave the car on a flat surface with the engine running and give it a minute or so for the oil level to settle. The oil level gauge should read somewhere around the 1/2 - 3/4 mark (mines usually a little under) and the dipstick should show a reading. The dipstick is a pain and you need to make sure it's fully inserted to get anything to show.
Oil is added slowly with the engine running and fully warmed up, as above. Do a little at a time and keep an eye on the gauge as you don't want to overfill!
Cheers/John
Jonttt
I've got used to doing this after a run rather than my usual practice with other cars which would have been to check on a cold engine before a run.
I've even bought a nice 1 litre filling bottle from Halfords which has a nice long neck and makes it so much easier for the regular topups these cars need.
On advantage of the engine being at the back is you can see the gauge though the rear window whilst filling lol
...for the regular top-ups these cars need
Really? Mine must be good, then, as it very rarely needs any oil in between yearly services, at 148k mileage, too. Always check regularly on the stick.
ORIGINAL: pse_SC
Hi Paul, mine is variable. Did not use a drop on about 1700 miles from Scotland to Leipzig and Stuttgart and back. Then a couple of fairly short journeys (50 miles each) and half a litre was needed. It really depends on how the piston rings lay while the engine is cooling I think.
Hi again, Mark... what you said here equates to "˜depends on which way the wind is blowing'... ?
