child / baby seat
- Thread starter stevecs
jboult
Interesting about the Stanmore service - I've talked to them a couple of times about this and they've quoted me nearly three times that amount each time (admittedly including fitting). What they usually say is that just lengthening isn't enough as you still get 'buckle crunch', so the system actually needs completely changing. I'm interested to hear what they actually did with yours, as I still need to get two seats fitted once the car comes back from the rebuild...
Cheers/John
tomwinton
TBH, I didn't give them the opportunity to discuss - this was all done by post. I removed the belt and cartridge from the car, posted it to them - they fitted a longer belt and returned. £54.50 rings a bell.
I looked at buckle crunch with Babyworld - they were happy, as was I, when they recommended this seat.
This seat is a bit different to most - the belt is used across the lap pad to belt in both the seat and the child - there's no extra belts within the seat for the child. THis allows the torso to move, and reduces the instance of neck/whiplash injury should the worst happen... This different approach helps with buckle crunch as the seat has a different profile...
Hope this helps!
Ta
TOm
