sawood12
Me again with yet questions on chips and ECU's. Alot of you already know I effectively have 1/4 of a Promax level 2 kit fitted i.e. a DPW and Piston style recirc valve with standard ECU chips and FPR. I fitted it with the intention of going the whole hog to a Promax L2 kit, however I've since discovered that the Promax chips are designed for use above 1 bar boost working in conjunction with the Bosch 3bar FPR which is a bit more than I originally intended to take the car to. I would probably want to take it to 0.85 to 0.9 bar boost as I want to squeeze a bit more life out of my cylinder head gasket. So what are my options regarding ECU chips that I can run upto 0.9 bar boost with assuming and can I run upto 0.9 bar boost with a std FPR? Are there any options?
