Chip Upgrade
- Thread starter porkersc
http://www.911chips.com/index.html
The fact that it is designed to be used with a cat bypass suggests to me that it is designed for the US spec engine originally with a cat and lower compression rather than a high compression euro engine, but who knows. You have no idea when the chip was made, whether it is pushing the ignition timing past safe levels, etc. The only safe route and guaranteed route is to get the car dynoed, get a chip burned based on the AFRs and get it retested to see the change. Even that assumes all the other variables are the same or compensated for. Unfortunately, 3.2s seem to vary too much for confidence to be placed in an off the shelf chip IMHO. If you do buy off the shelf then at least SW has lots of experience, seems to produce a safe chip and certainly offers very good customer service.
HTH
porkersc
Poss thinking that it may be worth paying the extra for a Mr Wong chip and the peace of mind it won't blow my engine up!!!
IanHighfield
I would pop along to Colin at 9M given how near he is to you !
