Cleaning out radiators and fitting mesh grills on my 986
- Thread starter Scrounger
i have been dodging rain showers today but wanted to get this job done this weekend as the ‘good weather’ seems on its way out now here in Sussex. Autumn is here and winter seems on its way!
I have watched a few videos regarding the removal of bumpers and completing this task. There’s various ones to choose from. One of the shorter ones is here (about 5 mins)
https://youtu.be/N7J4bhz9brg
My radiators looked like this;
Allow about a day to do this if like me you are juggling demands of kids/family. Dodging the weather and have other jobs to do (I wanted to look into an issue with the heated rear window, fit a new air filter and new headlight bulbs (to brighten up the commute). It’s also handy if you can get a second pair of hands to refit the bumper also.
I bought some race mesh from Amazon and I have cut and shaped two grills to sit behind the bumper. I hope this stops the worst of the leaves and debris to find its way in. Click this link for the race mesh.
AUTOSTYLE TG1253Z Race mesh aluminum black - diamond design 16x8mm - 125x25cm https://www.amazon.co.uk/dp/B005BP79ZS/ref=cm_sw_r_cp_api_glt_fabc_ABQ96S500EMKNDS3F3S6
when I cleaned mine out (this is the first time that I’m doing this - I bought my car in august). I found quite a lot of damp debris and leaves and alarmingly a piece of woodchip (see pics).
Anyway everything is now clean/clear. I have fabricated the grills and fitted these (see pics)
The bumper was tricky to refit but after some encouragement (and some swearing) everything is back where it should be!
I fitted a plastic mesh.
This was the mesh I fitted, bought from eBay.
Also easy to cut and attached behind the cross-bars by 100mm cable ties.
Advantage of the openings being open is that you can get in to remove debris but being open the condensers are prone to damage.
Once the mesh is fitted, its stops a lot of debris getting in but limits you getting in to clean out.
I normally remove the wheel arch liners twice a year for cleaning and to remove stones from the fan shrouds which can jam the fan impeller.
So in removing the front half of the wheel arch liner you then have access to the base of the condenser for cleaning.
