Cleaning the soft top cover
- Thread starter elliotw
BartyB
If you decide to try it, use it sparingly and test on a small less obvious area first with a Q tip. Just rub gently to ensure the solution makes contact with the mould. Don't let it dry and rinse it off with plenty of water within 5 minutes.
All being well you should notice the green discolouration begins to disappear. Repeat as necessary. Extend the contact time proportionally to deal with heavier levels of green mould. I should say that the usual caveats apply here. If you use too strong a solution or leave it on too long or don't rinse it off then you risk bleaching the hood material.
After the mould has been removed with the Miltons, the hood should then rinsed very thoroughly with water. Following this it should be cleaned with a cleaner/reproofer system (my preference is for either Autoglym or Renovo).
Hope that helps.
