Can anyone help with this rather annoying problem? When driving my 1985 lux at slow speed, I can hear a clicking noise, not exactly sure where its coming from as it dosent happen when the car is stopped, only when the wheels are in rotation. A good indication though is, when I tap the brake pedal lightly it makes the same clicking sound. When the brake pedal is fully depressed the clicking stops. I've replaced the fronts discs and pads, bled the system and no change. Anyone with any ideas before I haul it off to a specialist for a major bill ?
Clicking noise ?
- Thread starter JohnSnell
sdelasalle
Check tyres for stones.
Steve
Steve
Are you saying it makes the same clicking noise when the wheels are turning or when stationary and you tap the brake pedal? If so do you mean tap and release the brake pedal so it's like a mechanial noise associated with the movement of the pedal itself? Is it the same noise as when the car is moving, or is it possibly just similar?
I haven't got a lot of ideas, and none if the same noise occurs when rolling or tapping the pedal when stationary.
It's possible that it's a CV joint in one of the rear drive shafts - does the noise only occur under acceleration or overrun?
A completely different suggestion is that I have had a clicking after the door has been closed which was due to a dirty plunger in the door shut (the clicking was a relay).
