Hi
I have an 87 2.5 NA 944. As I was pulling into the drive something under the bonnet seemed to vent steam quite violently. It seemed to be coming from the front of the engine on the drivers sidenear the top, afterwards there was a very small puddle of coolant under the car. Revs were just above tickover when it happened and I had been poottling around before hand so the engine was not especially hot or stressed. Temp and oil pressure were all normal before hand and it was running fine. Started up again ok afterwards.
I had a good poke around and could not find any split hoses or anything else obvious. Did not loose much coolant either.
Is there any sort coolant pressure relief valve which could have operated?
I am a bit stumped as to what happened, and slightly concerned that this could be head gasket issue.
Any advice would be greatly appreciated!
Barnaby
Barnaby
