Clunking noise when gently taking up drive
- Thread starter Scrounger
AndrewCS
Dobson said:Pretty much since owning my car (GTS 4.0 Cayman), I’ve sometimes noticed a single clunk from the rear when gently accelerating after slowing to < 5mph (at a roundabout for example). Is this a “normal” noise from the LSD or should I be worried?
Can you feel the clunk through the drivetrain ... i.e. is it mechanical ?
A degree of backlash in the drivetrain - gearbox, final drive and driveshafts - will always be present, the extent being depending upon manufacturing tolerances. For starters, you should be able to check for play in the driveshaft CV joints.
Jeff
