clutch fluid
colin smith
I noticed that the fluid in the clutch Reservoir was nearly down to the min mark. Anyone know what the best fluid is for topping it up?
Brake/clutch fluid that meets DOT4 approval. Check there are no leaks on your system. The slave is on the passenger side beside and above the starter motor, and with a torch try and identify any leaks.
Correct me if I am wrong, but I believe the brake system uses the clutch master as backup in case of fluid loss, so check your brake system too (both brake and clutch systems have to be bled, after brake fluid change). See Clark's Garage.
ORIGINAL: wibble
I've read that too, I think the reservoir is shared on LHD cars but separate on RHD.
ORIGINAL: Riverside
ORIGINAL: wibble
Yes correct. It only applies to left hand drive cars...
Try looking at the clutch line between the master cylinder and the top of the engine. It has a connection on the back of the master cylinder that can get britle over time + weep fluid...[ rubber to metal connection..]
