chrisg
All
I'm just starting to put my 951 engine back together following a burnt exhaust valve and scored bore(s) at Mallory last September.
Having read various articles about clutch replacement etc, the halls sensors at the back of the engine can be a pig to locate and gap correctly.
I've heard it suggested that if you 'slot' the two holes in the clutch cover by simply hacking/ cutting through them you can solve this issue and 'future proof' a lot less hassle when it comes to removing the engine or clutch another time. In addition to this you can very accurately set the .8mm gap between the hall sensors and the flywheel/ ring gear.
Question is, has anyone else done this ? And if you do it, does it affect the structural integrity of the clutch cover ?
C
C
