yipadee
I fitted clucth slave cylinder and found out it was the master so have replaced that also, although i have cracked the rubber while fittimg the pipe from top of cylinder to pipe which connects to the reservoir, short of replacing again at £60 a go any suggestions, silicone sealant perhaps or just keep topping up, or will it even make a difference is only gravity fed as long as cylinder is lubricated.
I am open to advice/suggestions!
cheers
cheers
