Mckay
Wonder if anyone else has had this. On my way in to work this morning i heard a whuring noise when i fully press the clutch pedal right to the floor. If i leave it even half an inch short nothing but push it that little bit more and you get the noise.
The clutch seems fine no problems with that, i thought it might be a temperature thing, It seems louder when colder but maybe thats just in my head.
Also just while i'm on i am taking the car back into the dealers because i keep having an oil indicator failure on the trip computer followed by the needle on the oil pressure going down to zero then 2 seconds later it goes straight back to ok and where it was. I have read on previous posts when i searched it that it is quite a common little fault something to do with the small pressure switch which converts oil pressure into electrical signal at dash but will this work be covered under the porsche warranty?
Cheers.
Cheers.
