had my car serviced today at pc cardiff , on the fault read out sheet had fault p1137 clutch pedal encoder . i assume this must be the switch on the clutch pedal, is this an easy job to do ,also i assume that when i replace the switch the fault code memory will need to reset
clutch pedal encoder fault
- Thread starter rich mich
