chris_boyle33
a couple of weeks after buying my 1983 944 the clutch pedal has taken it on itself to stay about two inches from the floor. so far i've checked that:
The Spring to pull it back is still in place
clutch fluid is okay (but looks black - seals may need replacing)
there isn't much sign of seepage around the master and slave cylinders
there isn't air in the system
As it was parked outside in a bad frost i'm not sure whether the seals could have shrivelled but now fixed themselves. It drives fine, engaging and disengaging correctly, and isn't getting worse.
