Folks,
Has anyone come across a slight problem I am having with my clutch pedal and if so any ideas as to the culprit.
Symptoms:
Clutch works fine however the pedal doesn't fully return after being depressed. It ends up approx an inch below the brake pedal. It is easily pulled back by hand and holds at the right postion until depressed again.
Is it hydrolic or mechanical is the first question I guess, but any thoughts, anyone else had this ?
Simon
Symptoms:
Simon
