pauljmcnulty
Can anyone tell me if I'm missing something here, advising a 944 owner.
His clutch pedal intermittently won't return. I suggested master, slave or pipe between. His garage have told him there are no leaks, but the fluid was low so they've topped it up and bled it. It's still not returning properly, a week later the fluid is still there although it's only done a few miles. No obvious problem with the pedal itself.
Would I be right in thinking that the fluid won't be lost, to any degree, if not used? I assume it's only likely to be leaking when under pressure as you use the clutch? Or, could the piston in one of the cylinders be sticking, regardless of the fluid level?
