Rapsey0909
Hi all, trying to get my car up to scratch and done a shit load of maintenance to it since getting her last August. Belts, water pump, oil leak from cooler, new PS pump and recon rack and some welding was needed as well.
Some other bits going on now but when driving I’m sitting a little too close to the steering wheel and I'm not sure if there is something that can be done.
I'm fine with the hight but have come to the conclusion that if my clutch did not travel so far that I could sit slightly further back, just 2” maybe.
Now I did see that you can get a pedal stop that should bring the travel short of where it would need to be but not sure if that is a good idea because if you get that wrong and it does not open the clutch enough you might damage the clutch plate.
Another idea I had that would be to have an extra thick pedal pad so the extra rubber would act as a spacer so I can move the seat back by the same amount that the pad would be thick. But I cant find one (They do one for the mustang but is only in US and its quite expensive for a bit of plastic)
Has anyone experienced this or know another work around.
Thank you team.
Thank you team.
