clutch pedal
- Thread starter rs phil
It is difficult to say how big a difference this has made in terms of my own confidence and the balance of the car on track.
On the road, it may only be an irritation but !
George Elliott
I had this problem on a C2 Manual daily driver at 95k miles. I removed the slave cyl and it was clapped out. The fluid was literally black. I concluded the rubber seal in the cyl had broken down due to age & heat from the surrounding area.
I replaced the Master and slave cylinders. Not difficult. Parts cost £100 approx (Jasmine - can recommend them as they knew the parts and sent the correct ones). It takes about 2 hours to drain/flush, replace parts and bleed.
No problems now.
Its a frustration wondering if the pedal will return, but you can get nifty at lifting it[8|]
Good Luck
George
964C2
964RS
Richard Dawson
Given the credit crunch I'll live with it as it seem not to affect performance on jot!
Kind regards
