Clutch problem
- Thread starter simkin911
The reservoir is full, and I have bled the system (dirty fluid came out), there is no sign of a leak at either the master or slave cylinder. I have heard that the flexible hose can start to collapse or that one of the cylinders can suck in air, where should I start?
Tom
Waylander
Mr Don Seddon
I now have a new problem, the warning light for ABS has come on...
Waylander
[link=https://www.porscheclubgb.com/forum/FindPost/876786]https://www.porscheclubgb.om/forum/FindPost/876786[/link]
the nut started off at 11mm you need a good quality flare spanner like
[link=https://www.machinemart.co.uk/shop/product/details/pro71-3-pce-metric-flare-nut-wrench-set]https://www.machinemart.co.uk/shop/product/details/pro71-3-pce-metric-flare-nut-wrench-set[/link]
Normal 11mm open ended won't quite cut it
Chrishazle
It stemmed from when I was trying to replace the clutch slave cylinder; whilst attempting this I shorted out the terminals on the starter motor (this is probably what killed the alternator). I also disconnected some cables from the starter motor to allow a bit more room to work on the slave cylinder, what I failed to do was reconnect them all afterwards - doh!
So, many thanks to all those who helped with solving the problem, and the moral of the story is to disconnect your battery and make sure you reconnect everything.
