944_85
Two weeks ago I poped the question about the shudder, when I take off when the car is hot.
( Not sure how to copy the link to the previous post here.)
After a confirmation drive, it was confirmed that this only happpens when the car is hot, typically in traffic or after a few minute idle on the driveway. However when the car is cold, it is silky smooth.
Today I had the chance to get under the car, to change the gearbox oil, and measured the clutch. I measured through the hole, as descibed in the Haynes manual. According to Haynes measurments are 18mm = new, 34mm = time for a new clutch. However I measured 24mm. So I suppose I have to assume that the clutch material is not at it's end, and that it is only rubber centre which is starting to "disappear". Does this sound sensible? Or could it be something else?
Second question: As mentioned, I changed the gearbox oil, as I have alsmost no history of the car. (Only one fluid not changed yet since the purchase, and that is the brakefluid) While I was draining the old and cleaning the draining hole, I found some small pieces of metal inside. This was a bit of a shocking discovery.
Should I be concerned? Or can this be normal for a 24 year old car, where the gearbox oil might never have been changed?
