ollyporsche
I'm hoping the experts might help to diagnose a problem.
My 993 cab has done about 100k miles, over the past couple years there has been an occasional problem with a whining noise.
Typically it happens when in traffic, when the car is warm. Depressing the clutch everything appears fine, as you lift the clutch a whine can be heard from the rear. It doesn't do it all the time and I've only ever heard it when moving away in first gear although I presume it might happen in other gears but is not detectable when moving.
I've asked the OPC in Tonbridge several times if they can find the problem but unless they hear it they can't fathom it out.
Any ideas would be greatly appreciated.
