Clutch
- Thread starter 944Turbo
If I keep driving will it do further damage. Car is parked up for now but need to decide whether to drive it back or call RAC tommorow,
Cheers,
Tony
Indi9xx
Indi9xx
Diver944
If you do need a new clutch do you fancy a group clutch changing weekend? Mine is slipping on full boost now so I think it's time I upgraded to a horribly grippy versionORIGINAL: 944Turbo PS is it possible to change the clutch by removing the engine, leaving the torque tube / gearbox in place?
JamesO
Diver944
Indi9xx
Diver944
I may well take you up on that (later in the year when the piggybank has recovered [:-]). In the meantime LIL is absolutely fine at 0.8 bar boost and Tony had a drive of her yesterday and showed me that being just a little bit gentler with the throttle between 3000 rpm and 4000rpm can eradicate the slip at 1.0 bar and even 1.2 bar of boost. I couldn't help Tony with the installation today but I've just got off the phone to him and he's very nearly there now, just the CV joints, gear linkage and then exhaust to reconnect. I'm very much a basic DIY mechanic and it is a long, daunting process on a Turbo with lots of things to remove before you can get to the clutch but it is very much within the reach of two people working together and a good set of tools. Hopefully Tony will be on here before the end of the day to announce his success []ORIGINAL: Indi9xx If your interested, I can tell you what to buy and where from, and we will fit it for free!!
Diver944
