Clutch
- Thread starter ruane
pauljmcnulty
ORIGINAL: ruane
[] when I put my foot down on the accelerator reves go surging, when I do it gently and build up its ok : does this mean the clutch is sticking or needs replacing
Errr.....yes? [8|]
FIRST bleed the clutch fluid. Dirty job but someone has to do it. When was it last changed/bled?
Ensure transmission fluid is topped up and correct for the gearbox. Possibly replace fluid. Got to be cheaper than a clutch job.
Check clutch master/slave cylinder for leaking.
Check the roll pin where clutch pedal is attached to the cross shaft.
Oil leak on to clutch plates - replace gasket between engine and gearbox.
Pedal spring/stop adjustment, release bearing, fork spring etc.
bernard tester
I chose to replace the clutch (which had been in a long time) and the fork, bearings, guide tube and Master Cylinder --- just in case.
It has transformed the car. I may have spent £200 more than I needed, but I was spending the best part of £1000 anyway.
On the other hand, I had wasted £150 just trying to find out what was wrong, which had cured nothing.
