Is it possible to buy the coil lead on its own?
The last owner replaced the leads with some split fire things but the coil lead doesn't fit the coil and im sure its breaking down at times under load. I can hear it arcing and the car starts to miss and hold back occasionally at high revs and also the other day it started to pop and miss badly. I fiddled with the lead and it seemed to cure it.
All i can find is full sets of leads and il be buggered if im forking out for a full set when all i need is the coil lead.
Cheers,
Stu
Cheers,
Stu
