HI All,
I have just brought a 911 3.2 Carrera Targa ( 40th Birthday Present ), I want to bling up the engine a little, Has anyone applied heat shrink to the HT leads. I want to add a little colour in there, It should be more than possible to do this, has anyone else done this, if so, what diameter heat shrink did you use. The HT leads are 8mm/8.5mm ( I think) am I correct in saying that I should use a Heat shrink with a diameter of 16mm with a 2:1 shrink rate.
Or should I use a smaller diameter to ensure a tighter fit.
Any Help would be great
P.S The HT leads are new (ish), so I dont want to buy a new set just because of the colour. Another Idea, why cant the HT leads be painted. Any thoughts!!!!!!
