993paul
Driving to Classic Le Mans I suffered a progressive collapse of my electrics on my 993 (RS). It was in heavy rainfall, with full lighting on and commenced with the all instruments ceasing to work, although everything else seemed OK at first. Then after some manouevring at the Port the battery charge light flickered on and off (the clock seemed to be working), and by the time I arrived at St Malo the car started but then stopped completely 200yds off the ferry! Alarms and Monobloc went haywire and I had to be towed back on to return home [
]. as there were no Porsche Agenst able to help for 5 days,.
Later, I found the alternator was not charging (11.8 volts with engine running - after charging overnight). I then found the Fuse no 7 had blown (this was not obvious as it had not blown at the top of the fuse), and having replaced it - the alternator worked fine (14.0 volts) [:-] and the instruments sprung back to life. Now everything seems to be working again so my questions are:
1. Why does the alternator only work if the instruments are working? Is there a 'Teaser' electrical feed to the alternator coils via the instrument panel? If so why?
2. Why did the instruments blow in the first place? Are they prone to shorting out in rain?
3. Any other ideas welcome as I dont want this to happen again - especially in France!
The only good news was that I organised the Historic Lotus display which won the Concours Cup at le Mans [
] . However all the 50's and 60's Lotus drove there without incident, so I was given unending stick about PORSCHE being an acronym of Positively "˜Orrible' Revolting Schisse Hateful Electriknotworken has worn a bit thin now, BUT I'm left wondering why I sold my1958 Lotus 11 to buy a "reliable" RS??!![8|]
