Mac944
Hi All,
i've had a search but was unable to find all the info I was looking for so apologies if I've missed it.
I'm trying to verify whether the results of a compression test on a year old S2 race engine is OK or not.
According the the workshop manual it appears a fresh (stock) S2 engine has a compression of 8 bar (116psi) and I spoke with a well known Porsche specialist very familiar with 944s and race prep and they seem to think around 120psi is about correct but after looking around this forum and others I've seen results from stock engines with over 160k miles with a compression of around 160-170psi with suggestions that a new S2 engine should produce around 200+PSI.
Can anyone confirm what the correct compression should be for a fresh S2 engine?
Compression test procedure I followed:
Ran engine up to temp.
Removed plugs.
Opened throttle body to full.
Fitted compression gauge and cranked 5 times, measured reading and repeated for remaining cylinders.
Many thanks in advance!
Removed plugs.
