mr brightside
Invested in a Sykes Pickavant compression test kit over the winter to see if i could find out why the 924S smokes on hard accelleration, the car has been under wraps all winter so the engine was cold. Plugs were wet and crusty black on all cylinders but the dampness smelt like fuel that had bled from the injectors over winter. After i'd cleaned them up they weren't too bad, no pitting.
No 1 (Front of engine/NDE): 155psi, generated within 2 strokes.
No 2: 86psi, generated within 1 stroke.
No 3: 58psi, generated within 1 stroke.
No 4 (Back of engine/DE): 170psi, generated within 3 strokes.
The middle two cylinders were so far down i had to reperform the test but all was correct, my kit doesn't perform leakage tests but i don't think it's really necessary given the results. It strikes me as more than just a coincidence that the middle two pots are so bad, is this indicating anything in particular? Any comments appreciated, go nuts!
