Condensation in Headlamp
- Thread starter jboult
clyde
I occasionally get a bit of condensation in one or other of my headlights. I suspect it's the the effect of the warm moisture laden air cooling down inside the units when the lights are switched off. As the air cools it can no longer hold the same amount of moisture as when warm and dumps the water it can no longer hold as condensation on the coldest part of the unit, i.e. the headlight glass.
The units are not completely sealed and I don't think there's much you can do to stop this moisture laden air getting in at this time of year but it never seems to hang about for long.
Unless it's more than a bit of condensation I don't think it's anything to worry about
Mike M
"Hello Mike
You have stumbled upon one of the beauties of 993 ownership. That tube feeds into the rear of the headlight socket and drops down to a special aerodynamic connector on the underside. Its purpose is to pull ventilation through the headlight, preventing condensation inside.
Bit like the battery vent tube that you frequently find flopping about in the boot ...
cheers, Maurice "
Sorry about cut and paste, didnt know how to link the previous corrispondance.
Mike
clyde
ORIGINAL: Mike M
This might help its a historical responce from Maurice. I was installing HID's and came across a pipe and I didnt know where it came from, his answer was as follows:
"Hello Mike
cheers, Maurice "
Mike
I presume mine are still connected and that's why I only ever notice any condensation in the morning after it's been used with its lights on the day before. A brief drive certainly clears it with or wothout the lights being on.
