Condensation in Headlight
- Thread starter skendrick
964rh
Take out the unit.
Take off all the little spring wires things, making a note of which one goes where.
Take off the glass.
Clean out and replace all seals.
Re-assemble and put back in the car.
Or if you can't be ar5ed to do that, buy two new headlights like I will next time!!!![]
Dave Wilkinson
Before you are tempted to rush out into the garage to strip the headlights you should be aware of two things.
1) They will clear naturally given enough time
2) They will take you 1000 times longer to put back together than take apart!!
Rob's idea is a good one!!!
Dave
kevin
kevin
